Split a multipage TIFF, save a bunch of single-page images?
kaon
Post by kaon »
Is there a feature for splitting a multipage TIFF and outputting one image per page?
I suggest options for lossless single-page TIF or GIF or PNG or BMP output, and also lossy single-page JPEG output.
May need some basic file-numbering options too.
Also suggest the same for splitting a multipage PDF.
Re: Split a multipage TIFF, save a bunch of single-page images?
You have Tools/multipage/Extract
kaon
Post by kaon »
Thank you.
And PDFSAM "PDF Split and Merge" at http://www.pdfsam.org/ is useful for PDF.
PavlovDS
Post by PavlovDS »
Where this functionality in XnViewMP?
PavlovDS wrote:Where this functionality in XnViewMP?
As far as I know a function equivalent to the one in XnView Classic hasn't been added to XnView MP yet...
But you should be able to split a multipage TIFF into single-page images using Tools > Batch convert... in the Viewer if you load the file on the Input tab, ignore the Actions tab, and use these settings on the Output tab:
The settings marked in red seem to be required, other settings as you prefer; some experimentation may be required to get optimum results.
You may alternatively use XnConvert, which is effectively the batch conversion function of XnView MP.
PavlovDS
Post by PavlovDS »
Thank you. In the Russian translation mistake in this parameter - convert all pages in multi-page file. The English translation of the same - do not noticed
PavlovDS wrote:Thank you. In the Russian translation mistake in this parameter - convert all pages in multi-page file. The English translation of the same - do not noticed
I think the correct English is "Convert all pages of multi-page file. To avoid confusions I suggest a simple and short: "Convert all pages" or "Use all pages".
Reason/Background: The checkbox resides in the panel "Multipage" which makes it clear that these are settings for multi-page images. The checkbox controls whether all pages are converted or not (I guess only the first one is converted if not checked).
Note: Discussing the English translation is a bit off-topic and is supposed to be discussed in the topic ** English - English. But reason for this topic is a wrong English translation, so I continued discussion here.
