browser view size wrong after exiting picture view
Jou
Post by Jou »
Difficult to explain, easy to reproduce:
xnview 1.97 (.de full)
delete xnview.ini (i.e. reset to reallllly default)
Have a small picture, like 10 pixel wide, 40 pixel high. The height must bei 5x the width or more, shows the bug better.
Open it in xnview (like right-click-open-with-xnview from explorer).
Choose at the zoom button (between + and + zoom) from the drop down box "Auf Desktop anpassen, alle Bilder", in english probably "Fit to desktop, all picutres", 8th option from top, 6th option from bottom.
xnview will display the image as desired (in my case: zoomed to somewhat 250x1000, window size 250x1200 since it includes the menu bar).
Double click the the picture to get the browser view.
The browser view will then have the size of the window we just had (250x1200) instead of the normal browser size, much to thin to be usable, must be resized by hand to be usable again.
This bug also happens if: You open xnview first, then choose the picture, then choose the "Fit to desktop, all pictures" zoom, and double click the picture.
If it does not work on the first try (only happens if xnview.ini already exists), double click the picture within xnview browser again and the click the picture again.
This bug is in xnview for quite a while (at least a few years), I hoped it will disappear on it's own, but it did not, so I report it.
Joachim
Gaming in 4k / 6k / 8k / 15k / 16k? Yes! https://joumxyzptlk.de
