Browsing via keyboard
Karl02
Post by Karl02 »
I'd like to suggest to improve the keybindings for browsing with the keyboard.
When a directory in the directory pane on the left is selected, it is possible to browse through the directories with the Up and Down keys. However, if a directory has one or more subdirectories, it should be possible to open or close it with the Enter key.
Furthermore, it should be possible to switch to the thumbnail pane with the Tab key and back with Shift+Tab.
Valid also for the MP version.
-- Karl
Re: Browsing via keyboard
'-' & '+' are the standard keys
Karl02
Post by Karl02 »
xnview wrote:'-' & '+' are the standard keys
But only on the numerical keypad! However, the Left and Right keys also work, and they are much more convenient. But perhaps Enter could also be added, because it's more intuitive in my opinion and can be used to toggle between open and closed.
And the tab switching direction should work in the other direction, like in the windows explorer.
-- Karl
In windows explorer, you have only + & -, no?
How that?
Karl02
Post by Karl02 »
xnview wrote: In windows explorer, you have only + & -, no?
Yes, but an additional key won't harm, especially if it's intuitive.
xnview wrote:
Karl02 wrote: And the tab switching direction should work in the other direction, like in the windows explorer.
How that?
If the focus is on a directory in the directory pane on the left and you press Tab, then the focus switches to the file pane on the right.
-- Karl
