Is there a plug-in or does XnView have the capability to operate inside the Windows Media Center environment. Inside Windows Media Center there is a "more programs" menu item. My Adobe Photoshop Elements shows up in this "more programs" menu. I can view pictures inside of Media Center with Adobe Photohop Elements. I wish I could do the same with XnView. The normal Media Center picture viewer is very bad producing soft images. Adobe is much better but the interphase is not that good.
Thanks,
Mike
"More Programs" under Media Center
