24-bit audiofiles (wav etc)
ashira
Post by ashira »
I`m wondering if there is any way xnview can play 24-bit audiofiles? Or if I could make it play them/preview them using an external codec/app somehow from within the xnview browser window? (I mean a more convenient way than opening the files with accociated application.) If there´s no way to do this right now, maybe it could be implemented in a future version?
I know the primary use of xnview is with images, but I find its tagging and categorizing features makes it a good audio sample organizer.
/Johnny, new to this forum
ashira
Re: 24-bit audiofiles (wav etc)
Post by ashira »
Anyone?
XnView use installed codec
ashira
Post by ashira »
Thank YOU!
I just installed this http://chrisnet.net/msdn/AudioTypeConvert.zip which makes it possible to play 24-bit files in any DirectShow players (such as Media Player, Xnview). I just registered it from the command line with "regsvr32 AudioTypeConvert.ax"
and it works!
/Johnny
