Messy order when tabbing through tabs
In the XnView browser you can navigate through the currently opened tabs using shortcut Ctrl+Tab. When navigating, the order is confusing. And when mouse clicking on a tab, the tabs' tab order is changed again.
If possible, Ctrl+Tab should navigate to the next tab (the tab that is right of the current tab). Once the right most tab is reached, Ctrl+Tab should navigate to the first tab.
JohnFredC
Re: Messy order when tabbing through tabs
Post by JohnFredC »
Support++
John
ckv
Post by ckv »
I absolutely agreed. The whole 'move to last active tab' behavior is flawed and confusing in my opinion.
E.g. There's a same problem when closing tabs: http://newsgroup.xnview.com/viewtopic.php?f=34&t=16774
I've added F8 for that. I can't change the behavior of MDI client with Ctrl+Tab
xnview wrote:I've added F8 for that. I can't change the behavior of MDI client with Ctrl+Tab
Ah, o.k.. And Shift+F8 works vice-versa. Nice and probably best what you could do due to MDI client.
