IPTC Caption field + encoding
ueliash
Post by ueliash »
Each of my photos has an IPTC Caption field, all had been written on an XP machine with non-latin encoding.
In my case the encoding is CP1255 or iso8859-8. XnviewMP-0.21 displays it correctly on windows.
However when I browse the same files on linux (Fedora9), xnviewMP does not display the non-latin characters.
If I go the opposite direction and write the Caption field on a linux machine, the text is written in utf8 encoding
and xnviewMP on XP displays it is junk.
Since I shall continue to work with both OS, what is needed is a possibility to tell xnviewMP in which encoding to
interprete the embeded text.
By the way, picasa and digikam on linux fail precisely at the same problem.
Thanks,
U. Elias
Re: IPTC Caption field + encoding
By default IPTC is written with the local codepage, so it's normal. I'll add an option to write IPTC in UTF8
ueliash
Post by ueliash »
Thank you for the quick and positive reply.
I personally will be happy to have an option to read an existing IPTC Caption in a given encoding
(chosen from a menu), since I already have thousands of old photos with captions and I dont want
to loose them.
U. Elias
michaauskiel
Post by michaauskiel »
xnview wrote:....I'll add an option to write IPTC in UTF8
That´s great!
And what about the option ISO/IEC 8859-1 , MacOs, or ASCII??? :?:
Please, could you test XnViewMP 0.25
