Some JPGs display distorted
windozer
Post by windozer »
If I go to this webpage:
http://www.impawards.com/2009/serious_man.html
and then save the image from ther:
to my desktop and open it in XnView,
then the picture displays like this:
I'm using XnView 1.97 (Nov 27, 2009) on Windows XP SP3. And I don't have problems with other JPGs so far. So I wondered why XnView displays exactly this JPG distorted. In Windows Picture and Fax Viewer it displays normal.
marsh
Re: Some JPGs display distorted
Post by marsh »
The following will display a better proportioned image in this case:
Options... General > {Operations}> [ ]Adjust zoom if X/Y DPI are different
