Some usability suggestion for the paint tool:
a.) Double-clicking on a text should open the dialog for editing the text.
b.) Known Shortcuts should be supported (e.g. Del for deleting the currently selected vector, ...). See Clo's suggestions
c.) Cursor shape should show which vector object is inserted (circle, rectangle, ...). A simple version of this suggestion would be one cursor shape for all objects. This would help the user to see which mode he/she is in (sometimes a mode change occurs automatically without clicking on the toolbar).
Usability: Paint tool: Double-click, shortcuts, cursor shape
Re: Usability: Paint tool: Double-click, shortcuts, cursor shape
The FastStone Editor is an equivalent but more developed paint tool. The text input in it is much more smoother and by using FasStone Editor I sense that it and Pierre's Paint Tool for XnView is using the same but modified source? No/yes?
What I would really like to be able to do in Pierre's Paint tool is to be able to do different selection shapes both within XnView's viewer and within the Paint Tool, especially the freedhand selection, also know as Lasso select
I quickly made this to make clear what I mean:
maybe my request for the Paint Tool belongs in another thread...
• Hello !
• All missing tools and options are still listed THERE…… See Clo's suggestions…
- Not any drawing tool has been added, not even the essential pen¦pencil !
