How to extract image from slideshow
KOPOBA
Hello i have problem. I have slideshow in exe format its look like filename.exe . It was made by XnView and i want to extract images from this slidshow but i cant find tool to do this =( Plz help me
Dreamer
Re: How to extract image from slideshow
Hello, just press E key while slide show is running and select the folder to save pictures.
Dreamer
…just press E key while slide show is running and select the folder to save pictures.
• And no luck, the images don't appear in the resources (as bitmaps) with a resource editor (ResourceHacker)…
KOPOBA
yep dont work =\
with 1.97
• I tested with of course 1.97, XP-Pro SP2 and that doesn't work at all…
Dreamer
I think I know where is the problem. The exe file was created with older version. It has nothing to do with currently installed version. With the exe file created in 1.97 it works good.
Dreamer
