TESTED ON: XnView v1.97 (PortableApps edition) (don't know if it was always there or just a regression, I just discovered the shortcut recently)
____________________________________________________________________________
Here's a really simple but really annoying bug for anyone using keyboard shortcuts (so simple I'm pretty sure a video won't help any):
Turn on "Lock Zoom"
Hit the / key
Look at your "Lock Zoom" status - it certainly won't be checked!
Also, this happens with BOTH the standard and NUM / key.
I'm pretty sure the / key is supposed to be the keyboard shortcut to fit an image to your window WITHOUT toggling "Lock Zoom"...
Sort-of Off-Topic: Is it normal to have a year-old acknowledged bug not be fixed yet?
/ key (NOT ctrl+/) turns off "Lock Zoom"
