On Linux the functionality of XnView MP covers everything I have dreamed of for slide shows and foto management. Thank you for that work.
A few additional keyboard shortcuts and saved defaults however could allow a much more efficient workflow and thus allow using of the functionality how it deserves it.
In particular in the full screen viewer to not annoying the audience on fixing wrong display or preparing export, the following keys are missing and cannot be added in settings-->Interface-->Shortcuts-->View:
- ALT+C cmd_copyFileTo
- AL+M cmd_moveFileTo
- Del cmd_deleteFile
- cmd_rotate90
- cmd_rotate270
For cmd_copyFileTo and cmd_moveFileTo the previous destination must be retained.
The navigation dialog is unusable small and cannot be increased.
Starting View mode with disabled File Info cannot be selected as preference and must be manually entered with "I". This only works with histogramm "h".
Thank you very much
MP beta 0.21 Linux Keybord Shortcuts etc.
Re: MP beta 0.21 Linux Keybord Shortcuts etc.
Yes, view mode is not yet finished...helmt wrote: In particular in the full screen viewer to not annoying the audience on fixing wrong display or preparing export, the following keys are missing and cannot be added in settings-->Interface-->Shortcuts-->View:
- cmd_rotate90
- cmd_rotate270
Sorry but i don't understandStarting View mode with disabled File Info cannot be selected as preference and must be manually entered with "I". This only works with histogramm "h".
helmt
Hi Pierre,
thank you for taking care.
In Viewer Full Screen Mode the following is visible as image overlay
- file information
- histogramm
- player bar
The player bar can be turned off in Tools->Settings->View->Fullscreen->Showplaybar
The histogram can be turned off with keystroke "h". This "turn off is" remembeed across closing view mode and terminating xnview, whithout being visible in the settings.
The file information can be turned off, but on opening a viewer window in the same xnview session the file info reappers. This is annoying.
- file information
- histogramm
- player bar
Please, could you test XnViewMP 0.25
helmt
Sorry, with 0.25 on Linux for the View mode I see no change of behaviour.
I did also delete ~/.xnview to be sure.
