Scan: Aquire into active directory (of the folder tree)
x73
Post by x73 »
Aditional to the "File > Aquire into…" scan command, we need a ""File > Aquire into active directory" command. It enables to save batch scans into the currently selected directory of the folder tree.
Explanation: Almost every time I use the "Batch scanning" window, the destination directory is already selected within the folder tree. But with the current available "File > auquire into…" command, I have to select the destination directory once more within the "Batch scanning" window, which is somehow inconvenient.
Alternative solution: Add a button to the "Batch scanning" window beside the "Three dots button" and the "favorites" button, which instantly selects the current active directory of the folder tree.
(Please see the attachment)
Scan into active.png (11.43 KiB) Viewed 557 times
