This is another bug when using custom toolbar color. When using ToolbarBackColor option you will lose all your custom toolbar icons.RickS wrote: If I change the color (doesn't matter what color) of the toolbar (browser and view mode) I lose some of my icons. The ones that disappear are only those where the "Command" and/or "Icon file" reside outside of the XnView folder. For instance, I have an icon on the toolbar for Paint Shop Pro. In the Options>toolbar configuration the "Command" and "Icon file" settings point to addresses that reside outside of the XnView folder. This icon, and those similarly configured, disappear when I use Tweak UI to change the toolbar color.
ToolbarBackColor and custom toolbar commands
ckv
http://newsgroup.xnview.com/viewtopic.p ... 512#p81512 ==>
- Forum Librarian
Re: ToolbarBackColor and custom toolbar commands
This bug is listed as fixed in the changelog of v1.97.1 & v1.97.2, but I still doesn't work properly
[Start]
ToolbarBackColor=16777215
UseToolbarBackColor=1-
• It works, but the very annoying following downside:This bug is listed as fixed in the changelog of v1.97.1 & v1.97.2, but I still doesn't work properly
- If I set i.e. to test
ToolbarBackColor=#FFFFFF
I get alright the white BG as expected, BUT the pattern¦s of the *.ICO file¦s used for supplemental button¦s ( thus which is¦are not in the skin bitmap) disappear¦s, the whole icons¦ is¦are white !.
- I assume that this could occur with any stated BG colour.
- A bug in the same painting occured in previous versions (not for the tool-bar BG ? I don't remember exactly).
- The only good point is that the HTML colour code is supported…
• The bug is not fixed in 1.97.4… I sent you a screen shot via e-mail.
- It prevents to use this option, since I have several *.ICO for supplemental buttons…
