Sort by description doesn't work for folders
waily
Post by waily »
I had reinstall XnView and install XnView in different computer and try it
Sort by description works for files but not folder.
It seems that sort by description much like sort by name.
Re: Sort by description doesn't work for folders
you means that sort by description doesn't use description for folder,right?
waily
Post by waily »
xnview wrote:you means that sort by description doesn't use description for folder,right?
yes ...
waily
Post by waily »
Thanks for the fix !!!!
:D
