hdz format
Jephinger
hdz format
Post by Jephinger »
Greetings developers!
Whether there is a possibility to look hdz images?
This format works just as hdr
At present the program is able to read it only Keyshot http://www.keyshot.com/keyshot/
The sample hdz http://rapidshare.de/files/49142799/HDR ... t.rar.html
Re: hdz format
Ok, i'll check this format
Jephinger
Re: hdz format
Post by Jephinger »
Thanks )))
Re: hdz format
Do you know if specification exists for this format?
