I have a rather annoying problem that I just can't seem to solve. I want to navigate through Slide Show using the mouse buttons but whenever I do a double left-click it always leaves Slide Show mode. Right-clicks have no problem it's just the left-clicks. I tried disabling switching Full Screen > Browser in the Keyboard/Mouse options but that didn't work.
It's really a bit annoying when I want to go back to a certain image from a bit away back in the slideshow and end up closing it. I hope someone could help me with this problem. Plzkthnx.
Problem with Slide Show
Re: Problem with Slide Show
Do you menas Slide show dialog or quick slide show?
mgbenz
Slide Show mode not Quick Slide Show. The one in the Tools menu.
"Enable mouse navigation" is enabled?
mgbenz
Yes I did. The problem is, when I left-click fast enough, Slide Show closes and I don't know how to disable it.
Yes, double click is used to quit slideshow...
