MP 0.21 Mac: browsing Bootcamp partition
klayman
Post by klayman »
When I try to browse a NTFS partition on my hard drive, XnViewMP either freezes (and I have to force quit it), or it jumps to the same folder in my Mac partition (if such exists). For example, I try to enter "/Volumes/BOOTCAMP/Users/path-to-some-folder/" - XnView switches to "/Users/path-to-some-folder/" showing the path as "//Users/path-to-some-folder/" or just doesn't respond (sometimes even if /Users/path-to-some-folder/ exists).
If I start XnView with a file from the Bootcamp partition, I can view all files in the folder in fullscreen mode, but when I leave fullscreen, XnView sometimes remains in the current folder or often it switches to the Mac volume - I can't figure out on what this depends.
Nevertheless, I can successfully navigate to needed Bootcamp directory in the Folders pane and view files in it, but when I go to the Browser pane and navigate up the folder tree - all the same as above.
