NConvert/XnView plugins for 64-bit?
foxyshadis
Hello! I'm currently using 64-bit nconvert to process images that are too huge for 32-bit to handle. Is there any possibility that you could compile the format plugins for 64-bit? I'm most interested in JBIG and JPEG-2000, if that helps (I realize for lurawave, the only way to get 64-bit would be a secondary process shim, but I think Jasper should be compilable?), along with JLS and WMP. Thanks a lot for the hard work so far!
Re: NConvert/XnView plugins for 64-bit?
Please send me your email, i'll try to build it...
