Hierarchical Keyword import
PSHRutPark
Post by PSHRutPark »
I appreciate the inclusion of importing hierarchical keywords in XnView MP. Very useful.
However my hierarchical keywords are separated by "." (fullstop) rather than "|" ":" "/" or "\". The "." separator is used by the IMatch image management programme.
Would it be possible to include "." as one of the separators?
Thanks
PETER
Re: Hierarchical Keyword import
Please, could you test XnViewMP 0.25
PSHRutPark
xnview wrote:Please, could you test XnViewMP 0.25
Thanks for the inclusion Pierre.
While the "." option is shown in the Setting menu (the "|" is permanently greyed), it doesn't appear to have any effect on the Category display. That is, categories and sub-categories are not displayed as a branched hierarchy but each listed on a separate line"
as in the earlier beta:
location.aaa
location.bbb
location.bbb.hhh
location.vvv
Peter
The problem is if you have these files already in DB, IPTC will not be rereaded. Could you try with a clean DB?
PSHRutPark
xnview wrote:The problem is if you have these files already in DB, IPTC will not be rereaded. Could you try with a clean DB?
I repeatedly had deleted the db for XnViewMP and no change. In response to your message, deleted it again .... no change.
Peter
Could you try XnViewMP 0.26
