Fit images wider than window?
boogiepop
I think that an Auto Image Size option that would only resize those images that are wider than the window (and not those that are only higher than it) would be a great addition, especially to whomever uses XnView for their comics browsing needs.
Re: Fit images wider than window?
IT's not 'fit image to window width'?
boogiepop
Nope, as that function also stretches images that are smaller than the window.xnview wrote:IT's not 'fit image to window width'?
Oh ok, so a ''fit image to window width, large only'boogiepop wrote:Nope, as that function also stretches images that are smaller than the window.xnview wrote:IT's not 'fit image to window width'?
boogiepop
Exactly! Do you think it would be possible to add it in one of the future versions?xnview wrote:Oh ok, so a ''fit image to window width, large only'
Yes i think in the future major version (1.98)boogiepop wrote:Exactly! Do you think it would be possible to add it in one of the future versions?xnview wrote:Oh ok, so a ''fit image to window width, large only'
boogiepop
Awesome, thanks a lot.
