I am using Xnview on a terminal server with users that speak English and French. When the user changes their language and leaves the session the language for that user does not save. Is there a registry setting i can change or do i need to create an .ini file for every user profile.
Thanks
Warp33
Language settings on terminal server
Re: Language settings on terminal server
Strange, do you use registry or .ini?
It's in "Language" field
warp33
As it is now we have only 1 .ini for the server.
1 ini for all users?warp33 wrote:As it is now we have only 1 .ini for the server.
