Export dialog - File extension not added (FIXED)
Dstruct
Post by Dstruct »
XnView 1.97.2
-> Create a folder named "[phoke62] v.a. - Sklandu rausi" (without quotes)
-> add a jpg or png file to it
-> open it in XnView
-> Export as jpg or png to the same directory but in the save dialog remove the file extension from the file name!
-> Save
=> Correct file extension not added automatically to the file name!
Example:
-> 1.jpg opened
-> export as filename "2" (without quotes and ".jpg" removed) and file type JPG
=> File "2" created (instead of "2.jpg")!
This is somehow related to the folder name. Also this doesn't happen in the "Save as ..." dialog (there the extension is added properly)!
FIXED (1.97.5)
Re: Export dialog - File extension not added automatically
Dstruct, what are your settings for...
  • Tools » Options... » General » File operations »
    • » For 'Save as', use same original pathname & format
      » If no extension, add it
Dstruct
Post by Dstruct »
XnTriq wrote:» If no extension, add it
That's enabled!
As I said:
1. It doesn't happen in the "Save as ..." dialog at all!
2. It only happens in the "Export ..." dialog and only when saving to certain folder(names)!
Can't you reproduce it?
FIXED (1.97.5)
Dstruct
Post by Dstruct »
No one?
Here another problematic folder
d:\when we play live... - Breitbandkater\single cover files\
Exporting to this folder without extension doesn't add the extension automatically :(
FIXED (1.97.5)
Dstruct
Post by Dstruct »
Anyone can confirm?
FIXED (1.97.5)
Dstruct
Post by Dstruct »
No reply from a developer?
FIXED (1.97.5)
Dstruct wrote:No reply from a developer?
I'll check soon this problem...
Dstruct
Post by Dstruct »
Ok, thanks!
FIXED (1.97.5)
