Resize but don't inflate
adam
Post by adam »
I like using your tool and am using it on batches of images. The commands I am currently running are similar to:
Is there an option I can add to this to prevent it from inflating the image? For example if the input is of size 200x150, I would like nconvert to just convert it to JPG and not expand it. Is this possible?
Thanks in advance,
Adam
Re: Resize but don't inflate
-rflag decr
adam
Post by adam »
Thank you very much!
Your help is much appreciated.
