Sort By Folder does not work
Xip
Post by Xip »
In the View menu there is an option to Sort By Folder. However, selecting this does not sort and the dot marking the current sort selection does not change. A working sort by folder (path) would be invaluable after selecting "Show files in subfolders".
"Sort By Ratio" have the same problem.
Re: Sort By Folder does not work
Xip wrote:In the View menu there is an option to Sort By Folder. However, selecting this does not sort and the dot marking the current sort selection does not change. A working sort by folder (path) would be invaluable after selecting "Show files in subfolders".
Right
I can't reproduce it
Xip
Post by Xip »
According to the changelog for 1.97.5 this should be fixed. However, the same bug is still in 1.97.6.
