Problem with spaces in output file path in command line
wkone
Post by wkone »
I try to make a command line to get a screen picture and to create a jpg out of it. The forum topics helped me a lot and I have this command:
"C:\Program Files\XnView\xnview.exe" -capture=desktop,c:\temp\monrep\file.jpg
With no spaces in the output file path, everything is ok: a file named file.jpg in created in "c:\temp\monrep\"
Now if the output directory contains a space character, this is what appends:
"C:\Program Files\XnView\xnview.exe" -capture=desktop,c:\temp\mon rep\file.jpg
The created file is: "c:\temp\mon.jpg"
"C:\Program Files\XnView\xnview.exe" -capture=desktop,"c:\temp\mon rep\file.jpg"
The created file is: "c:\temp\mo.jpg"
Very likely there is something strange in the interpretation of the output path...
Version of XnView: 1.97.2
Did I do something wrong or is there really something strange in the way the output path has been interpreted?
Any help (or fix ;) ) would be greatly appreciated,
Best regards
Re: Problem with spaces in output file path in command line
This one must work!
wkone
Post by wkone »
Yes, it should... But I tried once again to be sure and it does not. I really get a file called "mo.jpg"
wkone wrote:Yes, it should... But I tried once again to be sure and it does not. I really get a file called "mo.jpg"
So a bug
wkone
Post by wkone »
It seems so...
By the way, as my final goal was to grab the content of the clipboard when I encounter this issue, maybe you have a clue for this:
- How to create a file with the clipboard content in command (http://newsgroup.xnview.com/viewtopic.php?f=35&t=19546)
Thanks a lot
wkone
Post by wkone »
So a bug
Hi Pierre,
I would like to know if this bug has been fixed.
How can I see a complete list of the changes for all the latest versions of XnView?
Thx a lot,
Regards,
Wkone
[quote="wkone"
[/quote]
No not yet, sorry
You can use "-capture=desktop,c:\temp\mon rep\file.jpg"
