Rotate color TIFF image while maintaining the file size
c00r
Post by c00r »
Hi.
I just downloaded XnView to rotate TIFF images by 180 degrees. After doing so, i noticed that the output file size is now so much larger from 713KB to 38,213KB. Here is the output of NConvert v5.60:
A TIFF (jpeg) (RGB) - JPEG was recognized : 2.tif
Width:2680 Height:4862 with 16777216 colors
Nplanes : 1 Bitscount : 24
Bytes Per Plane : 8040
xdpi : 300 ydpi : 300
Rotating : OK
Conversion of 2.tif into 2-a.tif OK
I used the following command:
nconvert -v -out tiff -o 2-a.tif -rotate -180 "2.tif"
Is there a way to maintain the relative file size after rotating by 180 degrees?
Thank you so much.
Re: Rotate color TIFF image while maintaining the file size
You have -c to change compression...
