Xnview convert does't work anymore
Kinghelmo
Post by Kinghelmo »
Hi,im new here..I have problem to convert my pic..last week it work well..but now it doest work anymore..I convert my jpg into png,but still jpg..other format also..I tried reinstall and I get error,the message is
Error creating registry key:
Hkey_local_machine\software\registeredapplications
Regcreatekeyex failed; code 5
Access is denied..
Can someone can help?
Re: Xnview convert does't work anymore
By 'batch convert'? Do you have 'use original format'?
Tools » Options... » System integration » Integration » Save options » (•) as INI in folder » [ User ]
