MP 0.25 Win - Find-as-you-type in file names AND metadata
andrea.ippo
Post by andrea.ippo »
MP should allow to search RAPIDLY (i.e. using the new search bar/find as you type) within metadata. Currently searches performed using this bar are limited to filename search.
It would be nice if the user could choose what kind of metadata to search in, adding three checkboxes (EXIF, IPTC, XMP) in the preferences/settings.
If no box is checked, the standard filename search is performed as the user types his query.
andrea.ippo
Re: XnViewMP 0.25 - Find-as-you-type in file names AND metadata
Up
Is this going to be considered for the next beta?
