Saving Print Sizes
KEiLER
Saving Print Sizes
Post by KEiLER »
Hey guys.
Does anyone of you know if you can save the printing sizes? For example, there is "Best fit to page", "Scale", "DPI", "Custom", etc. Now lets say you have 2 or more print sizes that never change. Instead of changing between them by typing their width & height under "Custom", it would be much easier to save those sizes...
Does anyone know if there is a way to do something like that? Maybe editing some preferences file, or can / will that be implemented in one of the next versions?
Thanks in advance!
Greets, KEiLER
KEiLER
Post by KEiLER »
Ok, so obviously it isnt possible to do something like that in the latest stable version. Could this feature be implemented into the next version please?
Greets, KEiLER
KEiLER wrote:Ok, so obviously it isnt possible to do something like that in the latest stable version. Could this feature be implemented into the next version please?
Ok, added in my TODO list
