MP 0.25 Win - Search - Recurse through subfolders issue
Dreamer
Post by Dreamer »
When searching for "*.*", "Recurse through subfolders issue" option doesn't work, only the files from current dir are found. When using just "*", it works good.
Dreamer
Re: MP 0.25 Win - Search - Recurse through subfolders issue
Right, '*.*' doesn't enter in subfolder... *.* can't be used on name like 'folder'!
*.* is Windows only :-)
