Minor "view as" issue
Evds
Post by Evds »
Choose "view as" thumbnail.
Choose "Tools\settings" and click OK to save the settings.
"thumbnails + labels" is active.
Thx for the great program !
oops66
Re: Minor "view as" issue
Post by oops66 »
Evds wrote:Hi,
Hello, right if i do step by step this procedure, I have this problem too with the MP linux 0.25 version.
But on the next start, I do not have it again.
Did you try with a fresh xnview.ini file and .db file ? , and did you try to save your custom layout via the panel: "Layout"\ Save Layout 1... ?
Evds
Post by Evds »
oops66 wrote:
Evds wrote:Hi,
I deleted the whole "Application data\XnViewMP" directory, i started XnViewMP and saved the layout but i still have the same problem when i open the settings dialog and click on OK.
I noticed a problem with "save layout":
Maximize XnViewMP, click on save layout 1 and then on restore layout 1. XnViewMP is no longer maximized.
JohnFredC
Post by JohnFredC »
Evds wrote:I noticed a problem with "save layout":
A bug in the QT libraries: See this thread.
John
