- 1. Open 0.25 browser
2. Select 2 images
3. Go to Tools->Compare
4. MP 0.25 freezes
MP 0.25 Win: Compare broken
							John
						Re: MP 0.25 Win: Compare broken
Right, same issue here with the Linux version
 XnViewMP  Linux amd64 -> Debian - MX - antiX
Fixed for the Linux XnViewMP 0.26 version,
Thank you Pierre
							Thank you Pierre
Hi Pierre
In 0.26 Compare opens successfully.
However, there is a strange problem with the Compare thumbstrip when the MP window is "Restored".
1. Maximize MP
2. Open Browser
3. Select two images
4. Tools->Compare
5. If not already showing, display the thumbstrip
6. Drag thumbstrip margin down to make thumbs smaller
7. Make the thumbs very small
8. Restore MP
9. Observe behavior of thumbstrip
On my system, the thumbstrip flickers quickly between two different sizes
10. Drag thumbstrip margin UP to make thumbs bigger
11. Thumbstrip stops flickering
1. Maximize MP
2. Open Browser
4. Tools->Compare
8. Restore MP
John
The thumbstrip flickering mentioned in the previous post does not occur in 0.26.1
							John
Hi Pierre... the 0.30 thumbnail rendering issues are also apparent in the Compare view.
Notice that the thumbnails do not fit properly in the thumbstrip (vertical scrollbar is showing).
John
Could you post screenshot of your thumbnails appearance settings?JohnFredC wrote:Notice that the thumbnails do not fit properly in the thumbstrip (vertical scrollbar is showing).
Hi Pierre
Here it is. This same issue applies to Layouts Film Strip 1 and Film Strip 2 and to the full screen thumbstrip (when the thumbs actually appear in it).... so it's just a problem in the math for calculating thumbs height.
John
Hi Pierre
v0.31 fixes this problem for Compare AND Full Screen.
But...
There remains a similar problem for Film Strip 1 and Film Strip 2 when the "small" toolbar has wrapped to two lines. The issue occurs for both "Thumbnails" and "Thumbnails + labels" modes:
But...
John
Problem not reproducable (in v0.84 the small toolbar shrinks but no longer wraps to two lines).
 Closed
