Long file name renaming trouble
seamoon
Post by seamoon »
When I rename a file name. If the name is long like below, home button doesn't go at the beginning of filename, instead it goes just before "34222323232"
I didn't have such trouble in ACDsee.
seamoon
Re: Long file name renaming trouble
Post by seamoon »
Am I clear? Just want to home button acts as any other app: Going beginning of the file name. So I can put much easier "+" mark for used or sent pictures.
Right, but it's the standard behavior of this control :-(
You can test in windows explorer...
Dstruct
Post by Dstruct »
xnview wrote:Right, but it's the standard behavior of this control :-(
Can't confirm this. Here (XP SP3) the cursor goes back to the beginning.
"|sil545456453434222323232.jpg"
seamoon
Post by seamoon »
I have Xp Sp3 too and Dstruct is right, this is Xnview's bug.
seamoon wrote:I have Xp Sp3 too and Dstruct is right, this is Xnview's bug.
??? I've tried in windows explorer (XP SP3), and i have same problem...
Dstruct
Post by Dstruct »
xnview wrote:??? I've tried in windows explorer (XP SP3), and i have same problem...
Obviously because you're using symbols or thumbnail view!Switch to list or details view and it'll work properly ...
But I must say that this is working fine here in XnView 1.97.2 too! I can get in front of the first letter fine via POS1 (HOME) key! No prob.
seamoon
Post by seamoon »
Yes I want this fix exactly for thumbnail view. I don't want switch other modes just because renaming a picture.
1.97.2 buggy too. Try my file name example: sil545456453434222323232.jpg
Dstruct
Post by Dstruct »
Working fine. Hit F2 ...
seamoon
Post by seamoon »
No, try my example press f2 and then hit home see it'll go at the beginning of jpg.
Like this:
sil545456453434222323232.(cursor is here)jpg
Dstruct
Post by Dstruct »
seamoon wrote:No, try my example press f2 and then hit home see it'll go at the beginning of jpg.
Like this:
This is what I get:
-> hit F2
-> hit HOME
seamoon
Post by seamoon »
After f2 the whole file name is highlighted (cursor doesn't in place where you were mentioned).
Dstruct
Post by Dstruct »
Not here. A dialog pops up in XnView. That dialog shows two edit fields. One with th suffix and one with the prefix (file extension). Cursor is placed in the first field. So it can't be in front of the extension because extension is in separate edit field.
seamoon
Post by seamoon »
I mean in place renaming which is faster & buggy.
Dstruct
Post by Dstruct »
Inplace renaming doesn't work here at all. I thought clicking twice would go into rename mode!?
