I am very often using function "Show all files (recursive)". I have folder "photos" and in the folder I have many of subfolders and this function show me all of the files. I very appreciate the filter which was missing in earlier version and it is the filter by folder. This is very useful and I always use it.
Now to my suggestion. The browsing is very complicated when you have about 1000 files in the list. Is possible to implement shortcuts like CTRL+PGUP and CTRL+PGDOWN to jump to next folder/subfolder? PGUP and PGDOWN will jump to next file, but CTRP+PGUP/PGDOWN will jump to the first image of next folder in the list. Also HOME/END will jump to the first file and end file in current folder, but CTRL+HOME and CTRL+END will jump to the first file in the whole list and to the last file in the whole list.
Very great will be also some possibility tu put FLAG to the file, bookmark, and then jump to this file by shortcut. You know, you want to jump to the another folder quickly, but then go back to the file which you was before. So you just put flag to the photo and then quickly jump to the photo. Like CTRL+ALT+0 will mark photo and ALT+0 will jump to the photo.
What you mean about these sugestions?
Thanks
Easier image browsing
mumajs
Re: Easier image browsing
XnView, do you think it will be possibel to implement something like I mentioned above? Jumping throught folders in "Sort by folder" will be enought for me...
mumajs
In Options-Browser-Filelist-Misc. is option Go to next subfolder (fullscreen). This function can be a little bit used as workaround, but this option is only going to subfolder in the same level like folder before. If I have photos in one level deeper then it doesnt show the photos.
I think my suggestion above can be implemented quicky, when I have a list of files sorted by folder then just put shortcut which will go to the next photo which have different path from current, up or down...
Path/path/path/image.jpg
