MP 0.25 Win EXIF vs. EXIFTool
JohnFredC
Post by JohnFredC »
I see that the ExifTool tab shows more fields (in MakerNotes, for instance), but I am confused by the need for two EXIF tabs.
What is the benefit of one versus the other?
John
Re: MP 0.25 Win EXIF vs. EXIFTool
You can customize the ouput of ExifTool, some users like that :-)
oops66
Post by oops66 »
xnview wrote:You can customize the ouput of ExifTool, some users like that :-)
Right Pierre, (or more accurately, I use to like that)
Congratulations for the implementation of the EXIFTOOL Pan, especially for the Exiftool Composites data !
I can now have access via XnView to my own composites data from my custom .ExifTool_config file.
-->JohnFredC
Exiftool is a powerful tool, by this way you have the ability to calculate automatically from the embedded meta-data (exif, iptc, xmp,...) if exist, some others custom data like:
CircleOfConfusion
FocalLength35 (35 mm equivalent)
HyperfocalDistance
LightValue
DOF
Image angles: height weight diag.
the CCD pixel size
geo-tagging calculation
so & so
See here:
http://www.sno.phy.queensu.ca/~phil/exiftool/
Here for an user Customization : ExifTool_config --> ~/.ExifTool_config (Under Linux with the perl version)
See faq item 11. "user-defined tags "
http://www.sno.phy.queensu.ca/~phil/exiftool/faq.html
An .ExifTool_config file sample:
http://www.sno.phy.queensu.ca/~phil/exi ... onfig.html
In French:
http://newsgroup.xnview.com/viewtopic.php?f=56&t=5478
JohnFredC
Post by JohnFredC »
Thanks oops66
I know about ExifTool and have sometimes used a GUI with it in the past.
If MP reads ExifTool configs, how does the user assign such a config to the ExifTool tab? ...put a config file in the Add-On folder with ExifTool.exe itself?
John
oops66
Post by oops66 »
JohnFredC wrote:...If MP reads ExifTool configs, how does the user assign such a config to the ExifTool tab? ...put a config file in the Add-On folder with ExifTool.exe itself?
If I am right (it was like that in the past, now I not sure), I am afraid that it is only possible under Linux and with the Exiftool Perl version ( not the stand alone Windows ExifTool.exe version - & located for example under the Linux directory /home/$USER/.ExifTool_config (my case) ) by configuring and using the ".ExifTool_config" file ( .* name file is not allowed in windows)
Edit: I have just seen an new option (for me), so maybe it's now possible to use this file under windows and the stand alone Windows ExifTool.exe version
exiftool -config ExifTool_config
I guess than Pierre has the answer ?
FYI: On Windows, the contents of the PKZIP-SFX file (ActivePerl)…
  • %PROGRAMFILES%\XnViewMP\AddOn\exiftool.exe
… are extracted to…
  • %TEMP%\par-{username}\cache-exiftool-{version}\
… when you click on the EXIFTool tab in the Preview/Info pane of XnVewMP.
IIRC, ExifTool GUI does this too.
