RE: Announcement: NConvert v5.60
DOS386
Post by DOS386 »
(brewing separate post to prevent split)
xnview wrote ( In http://newsgroup.xnview.com/viewtopic.php?t=19470 and "WhatsNew.txt" ) :
> NConvert v5.60 ... is available.
> Nconvert v5.60 XnView v1.97.1 (LIBFORMAT v5.60) 22/02/2010:
> Nconvert can now convert 48/64bits per pixel picture file.
> NConvert support 16bits per component loading (-org_depth)
> NConvert: -overwrite (overwriting is disabled by default!) - http://newsgroup.xnview.com/viewtopic.php?t=19081
Just those 2 changes ?
> NConvert can be downloaded on the NConvert download page.
The DOS version says 5.54 but is 5.30. Could you maybe compile a DOS version again, from 5.60 or the next version ? Of course, having the animation decomposition issues ( http://newsgroup.xnview.com/viewtopic.php?t=18846 ) fixed would be even better :-)
DOS386
RE: Announcement: NConvert v5.62
Post by DOS386 »
5.62 is out and DOS binary is updated :-)
XnView v1.97.3 (LIBFORMAT v5.60) 22/04/2010:
XnView v1.97.2 (LIBFORMAT v5.60) 28/02/2010:
Docs are not fully updated.
