[Fixed] RC2: "Replace / With" doesn't work if...
Locked
Dreamer
Post by Dreamer »
If "Name template" and "Replace / With" options are enabled in Batch Rename, "Replace With" doesn't work.
Re: RC2 BUG?: "Replace / With" doesn't work if...
Dreamer wrote:If "Name template" and "Replace / With" options are enabled in Batch Rename, "Replace With" doesn't work.
Pierre thinks that using a file template and replacing is not needed at the same time. Like you, I think this is a bug.
marsh
Post by marsh »
One box could be greyed out while the other is in use.
marsh wrote:One box could be greyed out while the other is in use.
Yes, then users would understand. But why limit functionality, here?
Dreamer
Post by Dreamer »
I agree, another question is what should be applied first, second, third (replace, rename, case)?
Yes, which order if i apply search on template too???
xnview wrote:Yes, which order if i apply search on template too???
1. Name template & extension
2. Replace characters
3. Case
Some explanation:
Case is easy. Since the user wants the filename and extension to have a specific case, you have to apply it last.
Typically, 1 & 2 are not applied at the same time. There's two approaches to decide on the order: Most possibilites or user interface design. I would go for the latter (without thinking about the possibilites). Since Name template & extension is at top, I'd expect it to be applied first.
Just my 2cents...
Dreamer
Post by Dreamer »
I agree with Helmut.
Dreamer
Post by Dreamer »
Fixed in RC3, thanks Pierre.
Locked
