XnView MP 0.26.1 win - Display of Canon G10 RAW (CR2)
APXAiA
Post by APXAiA »
I shot one photo using Canno G10 with RAW+JPG output simultaneously mode. When I viewed the two files (CR2 and JPG) in XNView MP 0.26.1 beta, I found they were displayed differently , recorded in the attached GIFs. XNView MP display G10 CR2 file is fast, It uses Embedded Thumbnail as default? The two file were displayed right in xnview 1.97.2, I had set the "Options"-"View"-"Misc."-"Camera RAW" to "Embedded Thumbnail" mode too.
Your work is beyond compare. Thank you.
GIFs:
In XNview MP, part graphic of G10 CR2 have several line shift.
APXAiA
Re: XnView MP 0.26.1 win - Canon G10 RAW (CR2) Preview
Post by APXAiA »
I've ever tried old version of XnView MP, the problem was there too.
oops66
Post by oops66 »
Is the pixel ratio height/weight, is the same for both ?
APXAiA
Re: XnView MP 0.26.1 win - Display of Canon G10 RAW (CR2)
Post by APXAiA »
Open these two files----
In Photoshop, CR2 and JPG is both 3312x4416 , display same content;
In XnView 1.97.2, CR2 is 1200x1600 ("Embedded Thumbnail" Mode and "Fit Image to Window,Large Only"), JPG is 3312x4416, display same content;
In XnView MP 0.26.1, CR2 is 3326x4432 (changed), and JPG is 3312x4416, display differently, looked like there were several lines---which are the side lines' copies---had been inserted while displaying.
oops66
Post by oops66 »
FI: Maybe you can try the MP 0.30/0.31 version (it's probably fixed ?)
see here too: Setting to load embedded preview or not for RAW - viewtopic.php?f=62&t=19800
http://newsgroup.xnview.com/viewtopic.php?f=60&t=21031
