Hello all!
I encounter issues trying to run Xn on Ubuntu. I created package as decribed here (btw, shouldn't that topic be sticky?), and installed it. Everything is fine, and Xn's icon appeared on desktop, but I couldn't launch it neither by icon nor by clicking on executable. Only with .sh file I managed to launch Xn, but it's not the option: it shows terminal with lots of unneeded stuff. So, how can I have Xn working?
Old version (I believe, 0-21) installed from package downloaded from this site worked fine.
And 2nd question, is it necessary to carry QT libs with Xn if I already have them installed?
Thanks in advance. I really wish to use Xn on *nix, 'cause there's no other such powerful viewer/editor.
Launch issues on Ubuntu
Fr0sT
Spread your wings and fly away
oops66
Re: Launch issues on Ubuntu
I have seen a script than create a deb file and install the latest version of XnViewMP (but in french), so if you want to install automatically XnViewMP via a .deb package on Ubuntu, maybe you can use this french script.sh and translate it ?
see here:
http://forum.ubuntu-fr.org/viewtopic.php?id=387143
dependency package : "links"
see here:
#! /bin/bash
# Variables pour les couleurs
FUSHIA="\033[1;35m"
NOIR="\033[1;0m"
BLEUFONCE="\033[1;34m"
VERT="\033[1;32m"
ROUGE="\033[1;31m"
# Version du net
xnviewmp_net=$(links -dump "http://newsgroup.xnview.com/viewforum.php?f=60&sid=cd7112513755712e2212c4331191d5de" | sed -n "/Announcement: XnViewMP / s/.*XnViewMP beta //p" | sort | tail -1)
# Version installée
xnviewmp_local=$(apt-cache show xnviewmp | grep "^Version" | sed "s/.* // ; s/-.*// ; s/b//")
# Comparaison des 2 versions
if [[ ${xnviewmp_net} == ${xnviewmp_local} ]]
then
echo -e "\n${BLEUFONCE}XnViewMP est ${FUSHIA}à jour.${NOIR}"
exit
fi
echo -e "${BLEUFONCE}Les versions de XnViewMP sont ${FUSHIA}différentes${BLEUFONCE} :
- Version du net : ${FUSHIA}${xnviewmp_net}${BLEUFONCE}
- Version locale : ${FUSHIA}${xnviewmp_local:-Non installé}\n${NOIR}"
# Création de l'arborescence deb
echo -e "${BLEUFONCE}Création de l'arborescence${NOIR}.\n"
mkdir -p xnviewmp/{DEBIAN,opt,usr/{sbin,share/applications}}
# téléchargement du fichier :
echo -e "${BLEUFONCE}Téléchargement de la derniere version${NOIR}...\n"
wget http://download.xnview.com/XnViewMP-linux.tgz
# Extraction du fichier tar
echo -e "${BLEUFONCE}Extraction du fichier tar${NOIR}.\n"
tar -xzf XnViewMP-linux.tgz -C xnviewmp/opt
# Renommage dossier
mv xnviewmp/opt/XnViewMP* xnviewmp/opt/XnViewMP
# Suppression du fichier tar
echo -e "${BLEUFONCE}Suppression du fichier tar${NOIR}.\n"
rm XnViewMP-linux.tgz
# Taille du dossier xnviewp
taille=($(du xnviewmp | tail -1))
taille=${taille[0]}
# Détéction de l'architecture
architecture=$(uname -m)
case "${architecture}" in
*64*) # Creation du fichier control du deb
echo "Package: xnviewmp
Version: ${xnviewmp_net}
Architecture: amd64
Installed-Size: ${taille}
Depends: ia32-libs (>= 2.7ubuntu17)
Section: graphics
Priority: optional
Maintainer: None <none@none.com>
Homepage: http://www.xnview.com
Description: XnViewMP lecteur et convertisseur de fichier graphique" > xnviewmp/DEBIAN/control ;;
Architecture: i386
Section: graphics
Priority: optional
esac
echo
# Création de la commande de lancement du logiciel
ln -s /opt/XnViewMP/xnview.sh xnviewmp/usr/sbin/xnviewmp
# Modification du script de lancement du logiciel
echo '#!/bin/bash
if [[ -n $1 && -e "$1" ]]
then
fichier=$1
else
fichier=${HOME}
fi
LD_LIBRARY_PATH=/opt/XnViewMP/lib
export LD_LIBRARY_PATH
QT_PLUGIN_PATH=/opt/XnViewMP/lib
export QT_PLUGIN_PATH
/opt/XnViewMP/xnview "${fichier}"' > xnviewmp/opt/XnViewMP/xnview.sh
# Création du raccourci
echo "[Desktop Entry]
Version=1.0
Type=Application
Name=XnViewMP
GenericName=Lecteur/convertisseur graphique
Comment=lecteur et convertisseur de fichier graphique
Exec=xnviewmp %f
Icon=/opt/XnViewMP/xnview.png
Categories=Graphics;
MimeType=image/bmp;image/gif;image/jpeg;image/jpg;image/pjpeg;image/png;image/tiff;image/x-bmp;image/x-fits;image/x-png;image/x-psd;image/x-xbitmap;application/dicom;" > xnviewmp/usr/share/applications/xnviewmp.desktop
echo
# Création du deb
dpkg --build xnviewmp xnviewmp_${architecture}.deb
# Suppression des dossiers
rm -r xnviewmp
# Installation du deb
sudo dpkg -i xnviewmp_${architecture}.deb XnViewMP Linux amd64 -> Debian - MX - antiX
Fr0sT
oops66, thanks =)
As far as I see, this script just automates actions described in "How to create deb package", but I'll take a closer look.
And still I wonder, what's the reason for not launching Xn... do you have everything working?
oops66
I don't know, your problem may come from several things.Fr0sT wrote:...And still I wonder, what's the reason for not launching Xn... do you have everything working?
Personally (and for the moment) I don't use a .deb file to install XnViewMP, I just decompress the .tgz Linux file, and create a desktop shortcut from the default xnview.sh file bellow:
#!/bin/sh
dirname=`dirname $0`
LD_LIBRARY_PATH=$dirname/lib
QT_PLUGIN_PATH=$dirname/lib
$dirname/xnview "$@"
Fr0sT
Aaah, that's it! .sh file is the one by which Xn must be launched! But I can't realize why it is required, why executable itself isn't working? And more, will file assotiations work?
marsh
With v.0.26, you can choose 'open with' (in most file-managers), browse and select xnview.sh for an image type.
oops66
... You also can use "Ubuntu Tweak" for customization (files assotiations, ...)
Fr0sT
marsh, oops66, I'll try, but I'd rather like to have file types associated from Xn's GUI, as it always been in Windows
