Hello.
I am testing xnviewmp on Debian Testing (Squeeze) Linux 64 bit.
What is the recommended xnviewmp version to use?
1.     XnViewMP-linux-libc6.tgz
2.     XnViewMP-linux.tgz
They 'both' seem to work.
Thank you.
						Debian Testing 64, which xnviewmp ?
Re: Debian Testing 64, which xnviewmp ?
According to,Re: XnViewMP beta 0.25
						xnview wrote:It's for old OS with old libc.michaauskiel wrote:Sorry, what does "Linux (libc6): " mean??? is this the version for a 64bit OS???
Does that mean the libc6 is the 'shared' version and libc is the non-shared library.
Either way, both work on a Debian Testing 64 bit Linux system with shared 32bit libraries.
Which version of xnviewmp should I use if I do not use the ia32 shared libraries?
Current libc6 Version:
libc6 : Embedded GNU C Library: Shared libraries , version 2.10.2-6
Thank you.
Thank you.
That is much newer than what old Debian "Etch" uses (glibc 2.3.6), for example.Katamara wrote: Current libc6 Version:
Here is the info my file manager reports about v.0.26:
Primary:
ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.8, stripped
Alternate, named "libc6":
ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.2.0, stripped
Related topic:
glibc version ...
To be clear...
The correct Xnview version for a Debian Linux Testing/Sqeeze 64 bit version is:
XnViewMP-linux.tgz
Because the libc6 is older.
Thank you.
XnViewMP-linux.tgz
Thank you.
