Open Images Small
Mike Truly
Open Images Small
Post by Mike Truly »
Let's say I have several images (all the same resolution) named:
name01
name02
name02
etc.
I want to use the spacebar to open them in sequence as XNView is being screen captured with a small window size. In other words, I don't want XNView to size the images to fill the screen. When I open image 01 and zoom out in XNView, I want image02 to open at the same size/position onscreen... and then image03 the same, etc.
Is there a setting that will allow the images not to be resized to fill the screen?
Thanks!
Sincerely,
Mike Truly
Truly Media
http://www.trulymedia.com
Mike Truly
Re: Open Images Small
Nevermind... I realized I could just size down the XNView window so that the opened images are at a size compatible with my screen capture.
Sincerely,
Mike Truly
Truly Media
