MP 0.26 Startup directory problem
Evds
Post by Evds »
XnView crashes when the startup directory does not exist.
Set as "startup directory" option: "last".
Start XnView MP, go to whatever directory and close XnView.
Delete the directory you last opened in XnView with explorer and start XnView again up.
XnView MP 0.26, Win XP
Re: MP 0.26 Startup directory problem
I can't reproduce. do you have the crash always?
Evds
Post by Evds »
Yes, i can reproduce it every time.
In the dialog the offset 001a94f5 is mentioned.
Evds wrote:Yes, i can reproduce it every time.
Could you send me your email by PM please
Please check XnViewMP 0.30
Evds
Post by Evds »
Thx,
Tested it in XnView MP 0.31 and the program doesn't crash any more.
But i have another problem now:
When the last used directory is deleted and XnViewMP is restarted the only item in the treepane is Desktop.
When i double click on desktop i can see "My documents", "This computer", etc but the column is so small that i can only
see the icon and the first few letters.
Windows XP SP3
