Dear xnview,
I'm trying to open and process 16bits TIFF images and got some problems.
I tested this images on XnView without problem.
I just got a message that said something like this : "the image will be open in 8 bits/channel...".
Then I can save in 8bits/chanel without any problems
I try to reproduce this with GFL.
With my debuger, I can see that images are opened with automatic convertion from 48 bits (3x16) to 24 bits (3x8).
But once I save its,the result is a stretched image (width divide by 2).
I shoud miss something.
I sent you an email with a link to the tested images.
Rgds,
Opening/Saving 16 bits TIFF images
dominique
Re: Opening/Saving 16 bits TIFF images
More info:
Using 2.90 -> No problem
Using 3.11 -> Problem
Dom
dominique
Not shure but I think the problem is while opening 16 bits images.
When I add text with gflAddText, the text is well added (color & position).
Hope it helps
Hope it helps
Dom
