Launch problem on linux
ueliash
Post by ueliash »
I extracted version 0.26 into a dir on a machine with Fedora 9 and try to launch it by running xnview.sh :
> XnViewMP-026/xnview.sh
The browser appears for a second, then crashes after
LOAD BITMAP </home/..................>
GFF :: LoadThumbnail : 2
LOADED from DB (119)
LOADED from DB (120)
BrowserWindow :: updateMenu()
XnViewMP-026/xnview.sh: line 7: 12174 Segmentation fault $dirname/xnview "$@"
Any advice?
UE
Re: Launch problem on linux
Please try to remove the .xnviewmp folder
ueliash
Post by ueliash »
Thanks, it solved the problem.
UE
