MP 0.26 does always crash at start up ... (Mac)
anview
I can't start the programm, it always crashes at start up.
How can i solve the problem ?
Thanx & Regards
XnView MP 0.26
Mac OSX 10.5.8
Thanx & Regards
XnView MP 0.26
Mac OSX 10.5.8
Re: MP 0.26 does always crash at start up ... (Mac)
A crash of all app?
Do you have pdf in the startup folder?
anview
Only XnView crashes.
you can see the main-window and then comes a message Xnview was closed ... and the next problem, i can't close this message-window. It poped up again and again ...
In which startup folder?
I copied the file in the program-folder and there is no pdf-file.
Is it possible to post a screenshot?
anview
"... the program was unexpectly closed ..."
path: users/name/
path: users/name/
If you click "ignore"?
anview
... the message pops up again ...
anview
btw:
you see, the menu bar hasn't the standard or default-look
if i uninstall and reinstall xnview, the menu bar keeps changed, it doesn't change to "standard look"
And if you click again ignore? Do you have eps or ps file?
What do you means? I don't see the menu bar here...anview wrote: you see, the menu bar hasn't the standard or default-look
anview
i mean the "main bar" (?) on top of the window - with "Fullscreen", "Thumbnailsize" etc.
if i click again "ignore" it pops up again and again ...
eps or ps- file ? i dont know what you mean ...
anview
aaaahhhh, i think you mean ps-files = photoshop-files
... no, i haven't
... no, i haven't
I don't see menu bar on your screenshotanview wrote:i mean the "main bar" (?) on top of the window - with "Fullscreen", "Thumbnailsize" etc.
Postscript fileseps or ps- file ? i dont know what you mean ...
anview
I don't see menu bar on your screenshotxnview wrote:anview wrote:i mean the "main bar" (?) on top of the window - with "Fullscreen", "Thumbnailsize" etc.
on top of the screenshot you can see f.i. "thumbnailsisze" ... this one and the other buttons are what i mean as " menu bar" ...
i don't use postscript-files.
regards
Oh you means the toolbar.... What is the problem??anview wrote: on top of the screenshot you can see f.i. "thumbnailsisze" ... this one and the other buttons are what i mean as " menu bar" ...
And for the error dialog box, i'll fix soon
anview
i think it is not the "standard-look" of the toolbar (?) why?
