XN View in Total Commander
quick
Post by quick »
even though this might be not a XN-View "Bug" I'd still be interested in your feedback in the following:
I'm using XnView together with Total Commander, since Total Commander has a very nice XnView integration. So it's possible to use the XnView engine as the default viewer in Total Commander. However this integration doesn't work with XnView MP anymore.
I might also report this "issue" to the Total-Commander developer, however you might be able to give me feedback where the problem comes from. Is it a XnViewMP bug or is it simply not possible to use the Total Commander integration together with XnView MP?
Thanks for your feedback!
Oliver
Re: XN View in Total Commander
Currently TC can't use XnViewMP engine...
quick
Post by quick »
Yes I know ;-)
The question is: Will this be added to XnView again or did the enginge change in a way so TC won't be able to use it anymore? In other word: Would it make sense to request support at the TC team?
Oliver
I'll add the support in the future
