Win 7 64bit: Unable to register for USB events (scanner etc)
GeorgD
Post by GeorgD »
On Win 7 Home Premium German 64bit, I can't register XnView as application for USB events (press F12, system integration, checking "add XnView as app to USB events" is forgotten instantly). Even when started as administrator. Solution via editing registry documented in http://newsgroup.xnview.com/viewtopic.php?f=35&t=5679 Not all users are able the hack the registry and for those that can, it's no fun, so a working option would be helping all ;)
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
Re: Win 7 64bit: Unable to register for USB events (scanner etc)
I've tried, if i click Option/'register....', next time the checkbox will not be checked, but USB events work!!!!
Could you confirm?
GeorgD
Post by GeorgD »
Pierre, I tried, does not work as normal user, even with restart, does work when XnView has been started as admin, no restart required, checkbox is not checked. Again an issue with Win7 where users shall be informed their action will only succeed when they're admin...
GeorgD wrote:Pierre, I tried, does not work as normal user, even with restart, does work when XnView has been started as admin, no restart required, checkbox is not checked. Again an issue with Win7 where users shall be informed their action will only succeed when they're admin...
Yes, right, XnView must be started with admin rights...
pierrederonsard
Post by pierrederonsard »
Are you sure it works when using administrator rights ?
It does not on my W7 64.
And the option remains unselected when I come back to the option toolbox...
GeorgD
Post by GeorgD »
pierrederonsard wrote:Are you sure it works when using administrator rights ?
For me, it worked.
pierrederonsard wrote:And the option remains unselected when I come back to the option toolbox...
Same here; it works anyway...
ckit
Post by ckit »
Doesn't work for me, just tried with Admin privileges and the AutoPlay manager in the Control Panel and nothing.
Also, I'm hoping Pierre will dump the current file associations eetup in XnView and switch across to the newer "Default Programs" system that is present in both Vista and 7. XnView does use it but only for about 9 types... needs .psd, .rw2...
foobar2000 and Media Player Classic use it really well except for supporting Blu-Ray discs?
