NConvert is currently failing to convert a PDF that is created from an Adobe Reader print stream. For example, if i open a PDF and print it with the GhostScript virtual printer to make it a PS file, NConvert can convert this file to Tiff fine. However if i convert that PS file back to PDF, NConvert cannot convert the PDF to tiff.
I have a sample file i can provide. Thanks in advance for your help!
NConvert fails to convert PDFs created Adobe Reader
jobermeyer
Re: NConvert fails to convert PDFs created Adobe Reader
Yes, please send me samples?
jobermeyer
I sent over a few sample files through email. Thanks!
