Batch Processing » General tab » Output section (Format: JPG - JPEG / JFIF) » Options button » General:Read/Write . . . make changes » exit out of XnView » go back in . . . changes are not retained.
Such changes used to be retained across sessions. But somehow, something has changed. I've tried everything I can to figure this out, but without success. If anyone can help, I'd sure appreciate it. Thanks. —Thri
Batch Processing parameter changes not retained
thricipio
thricipio
Re: Batch Processing parameter changes not retained
Apparently, the aforementioned parameter changes are retained across sessions if the Options dialogue is entered from the Browser screen.
So... case closed.
Thanks anyways. --Thri
So... case closed.
